You have to be OK with the Cold War Soviet Submarine look.
I do like the look of the new devices, too.
Got this in last night. Some tweaking is needed, however. The stock lube that is applied to the stabilizers is too thick and/or too generously applied, so much so that the keys with stabilizers get stuck down sometimes. I’ll be honest, before the purchase I did a bunch of research and saw a lot of people going into depth about what lube and exactly how much to apply, and I really thought it was being blown out of proportion, but now I understand why this all matters. When I take it back apart to address the stabilizers, I’m also going to lube the switches. Maybe, get rid of these stabilizers all together and go for some better ones, as I’ve heard these stock ones aren’t the greatest.
Dirocks don’t fit the aluminum plate so if you intend to use them. Some sanding on t the stabilizer will be required but after modding it’s all worth it.
which keys are sticking? I has a issue with the space bar sticking to stock stabs… when mounting the keycap don’t press all the way down on both sides just make sure it is mounted on the switch in the middle, like a partial mount. That fixed it for me and it’s been fine since. I only had this issue with the space bar.
Hmmm I’ll give that a try first. It’s really every key that uses stabilizers.
This is a reminder that i reallllly neeed to clean my keyboard. I thought my keyboard came with a kap puller but I cant find it. I keep it all clean when using it, but there is no avoiding skin cells and rogue hairs, as gross as that is.
Hifiman HE-500 arrived today. They still sound just as good as when I owned my 1st pair back in the day.
You know where the First Watt name comes from?
Uuuh… I think it comes from philosophy around the importance of the quality of the first watt
Nice!!! Can’t wait to hear what your first First Watt sound like!
Each model sounds different so your second First Watt will sound different than your first First Watt and third First Watt. But for now let’s just focus on the first First Watt.
What are you gonna to connect it to?
Yup lol pretty smart business model if you ask me
It hasn’t arrived yet but my pre! will be! a MicroZOTL MZ3 w/ LPS+ power supply
dayum, along with the first watt should be a sweet amp,pre,speaker,headphone setup
Great synergy there for sure lol, should be pretty fun
Give that man a cigar! And for the greater portion of our music consumption we don’t go above that most important first watt.
High efficiency speakers for the win!
I’ll try it as an integrated as well. I’m curious what 1 watt will do to with my Heresy iv’s.
Really hoping it’s to my liking. Took a bit of a chance here upgrading many pieces at once.
More than you might expect
Hopefully it works out for you, will be curious of your thoughts ![]()
That’s a soulful combination @don . Very cool.
