Ediscreation have a similar device with their fibrebox
Ifi Audio also has one.
Which is listed under Silent power division.
Both look good, unfortunately no option to replace the optical cable.
Where as with the larger devices it is always an option to try something from Cisco, Finsair or another optical cable that best suits the chain.
Probably all has its pros and cons I guess.
Thinking of purchasing a used (latest gen) Apple TV and modding it to remove the internal switching power supply and converting it over to an external LPS. They’re cheap and given the improvements I’ve seen implementing audio hobby improvements into my TV, I think this may be a worthwhile thing to explore.
I saw improvements in the display when I put in a hand me down power conditioner. I saw improvements when I plugged a Shunyata NR cable into the TV, I saw improvements when I bought a second Cisco Meraki to mod and used that as the Ethernet switch for the TV space.
The nice thing about the TV is that cheap seems to go a long way… maybe because there’s more noise there to begin with? Dunno. Anyways, I’ll fiddle around with this over the next couple of months and report back. It’s also a good way to repurpose the 8 disparate LPS I’ve got sitting around all over the place.
Will follow this closely ![]()
So how are you “extracting” audio from your AppleTV?
I’ve had pretty poor luck with standard spdif extractors, even with better cables and power supplies. I tried using various ddc and ended up fighting audio lag/sync issues. I’ve been tempted to try something more audiophile like this (with the 2ch output option):
But I’ve been generally pretty happy with airplay streaming to a Rendu endpoint. It’s not true bit perfect (it resamples to 44.1), but it’s the best sound I’ve gotten from it so far.
I’m vary curious if you’ve found a solution you like.
I mean, grab an old blu ray player and some physical disks and that will be the biggest improvement. Better yet set up a server and burn to there.
The cheap route. I’m getting the HDMI from the Apple TV and then optical out from the TV into the Pontus II
This may be a better topic from an AV thread. Do we even have an AV thread?
Them be some dirty bits ya got there!
I don’t think so, but we definitely should
Okay after some reading and hunting around for the right unit, I bought a 2nd Gen Apple TV 4K, the A2169 model which is a different animal than anything before it and anything after it. Shows some of apple’s corporate thinking and then be bean counters winning out, they always win out in the end.
Anyway, will document this as it’s a pretty basic little project but I’m going to follow two rules, it’s got to be on the cheap but it’s got to have the same foundational principal I’ve followed in my 2-CH. which is address every component in the system.
Interesting so I thought I’d share for anyone that’s gotten a bit over the top with their network optimazation. It’s also a relatively “cheap” tweak for an audiofool’s budget.
The thought process is thus.
We know the PC is filthy dirty noisy thing that needs to be kept as far removed from your audio gear as much as possible.
however… we all still sit in front of our PC connected via an Ethernet cable to the same switch that our expensive audio trinkets are also attached to! WTF?
In my example, it’s a Roon server, a Sonore opticalModule and a Lumin A1 streamer DAC.
So, I’m trying to address the obvious polluter in the switch and what I did to adress that is buy a cheap Ethernet to SFP converter. You know, the ones you trip over everywhere on Amazon for $30 to $40 bucks. This one came as a kit with two boxes and two transceivers but I’m only using one; That’s because my Meraki switch had a open SFP slot after I moved to connecting my Lumin U2 in my 2-CH setup via the Sonore opticalModule.
So in summary, moving my PC from an Ethernet cable (which you can see disconnected at this time in the pic) over to a short fiber run from the SFP converter to the Meraki switch.
I had a decent ifi power supply so I’m using that to power up the SFP converter. I threw the PS into the mix because I had it, but it’s not as critical here as it’s on the isolated side. The reason I’m using that though is to not introduce a dirty wall wart into the AC power as I’m connecting it to the AC conditioner all the other gear is connected to.
I’ve got to say that I did this purely on a whim based on nothing other than theoretical best practice, but I’m glad I did it. The PC was clearly shitting noise into the Meraki switch. The streamer is improved, ot crazy but certainly noticeable enough to be certain about it.
PS: don’t judge the dust and sloppy wires, this was still an in progress pic and wasn’t finished with setting everything up. lol
Following along with what @dB_Cooper just posted here is a good video by Hans who is one of the more competent folks presenting info on YT IMO.
@dB_Cooper, Please sir if you could assist, I want to add a heat sink to this etheregen unit just like the one i purchased form you. Can you provide assistance to what and from where I can purchase the paste and a proper sized heatsink please? Unit gets sooo hot, i need to dissipate the heat best possible.
I want to go from this:
to this:
Read your email.
You are the BEST dude! Thank you. ![]()
About a month ago, I decoupled my desktop from my audio switch using a fiber to Ethernet adapter. That had a noticeable effect, nothing major but certainly noticeable.
Yesterday I decided to remove my Roon Core from the audio switch as well. I installed it in my DMARC closet, so one jump away from my audio switch. Guess what? Yes another noticeable improvement, again not great but noticeable enough.
It’s almost as if the more dirty, filthy, noisy PC components I don’t have connected directly to my audio switch, the better everything sounds. These are definitely low dollar upgrades but still worth addressing and it all helps.
So I guess the moral of the story is, only have audio components and the minimal amount of components connected to the switch. In my case I’ve got the MoCA to Ethernet SFP adaptor, a fiber SFP isolating my PC, my Moun Ethernet filter I’ve got connected to the Lumin A1 and the Ethernet port of the Sonore opticalModule.
Anyone work with Ubiquiti Networks routers? I’ve been seeing them pop up a lot and read comments about their efficiency and speed. Still looking to get the most out of my home network and potentially upgrading everything at least in the wired backbone to 2.5 GbE.
My networking friend loves them and tries to get me to grab them all the time. They dont fit my scenario 100% and they were expensive so i always pass. Also an SBAFer gets rid of his “old” (1 gen /year behind) Asus mesh routers and they have been solid.
I think ubiquiti had a recent vulnerability exposed but that may be it.
I bought a Dream Machine Pro, one of their wifi access points, several of their 4-port switches when we got gigabit fiber over a year ago. More recently the L3 Pro Max 16. I like them. I’m not exactly network savvy, but i didn’t have any issues getting everything set up the way I wanted it. I don’t have any downtime issues. It’s been a solid purchase for me.
Can’t solve one issue with streamers. It was happening with Antipodes K50 and now Sonore Ultrarendu, so its not the streamer.
The streamer will keep disconnecting when switching songs and then no longer recognizable and have to reset it. Then when resetting it will be recognizable again.
This is not an issue with streamers that have screens like Wiim Ultra, only web browser based ones. (ip address).
Could it be a router issue? (Asus router). This router feeds both the PC and Streamer via Ethernet. But network and internet is perfect no disconnects or anything, just when switching songs the streamer needs to be reset.
Doubt it has anything to do with the screen.
There is very little in common between the K50 and the Ultrarendu, short of them both running a lot of off the shelf linux components, and maybe it’s an issue with one of those and the DAC. The only fix for that would be a firmware update for one or the other.
The only issue I see with my Opticalrendu, is it losing USB connection to the DAC, which really only happens when I have power outages, and that usually takes more than a quick restart to resolve it, it invariably involves a streamer reset and hard power off on the Lampizator, I’ve always assumed the issue was related to the uController in the Lampizator not booting properly after short power interruptions rather than a streamer issue FWIW.
FWIW the Wii series of streamers appears to run a unique software stack (still on Linux), I only know this because I’ve written my own playback software and they identify themselves differently and in some cases behave differently if you address them over UPnP to every other linux based streamer I’ve tested, everything else including the Antipodes is using some variant of MPD. That could explain the difference.
If you can get to the web interface on the streamer to reset it, it’s not a network issue.
