Build Log: Whammy Take Two
Further testing. Having reseated all the LEDs I have been able to conduct a proper test of the front panel switches. Input selector is now working perfectly. However the gain selector switch is playing up. The medium setting has a short circuit somewhere and I spent time tracking this down. I quickly ruled out the amp pcb side and the cable as culprits and then set to tracking it down on the front panel board.
After a deal of continuity testing I finally have my culprit. The two pole, three throw switch is outputting in a way that causes the short circuit. I suspect the culprit is that I used a substitute for my original specified switch and that substitute differs in it’s internal wiring. Having looked there is no way to rescue the circuit on the board so after all that I will be needing to redesign the front panel board after all! I am likely going to keep the under slung LEDs however. I think they will look better.
as Bob Ross used to say, happy little accident.
Indeed! I am not too worried. I’ve ordered the replacement parts, now back to the drawing board on the pcb.
Further investigation:
Checking my circuit design I came to the realization that the switch layout was not to blame. In fact, the circuit as is ought to have worked however…
It goes back to the initial issue with the LED units having the polarity reversed to my expectation. Yes I could physically reverse them however this fundamentally altered the way the circuit works in a way that caused one switch led circuit to short with another in one specific setting due to the way that SP3T switch works.
So regardless of any other issues, the main problem remains the LED connections and so I have redesigned the pcb and ordered new versions.
[edit] I’ve totally lost track of them being over or under slung leds at this point so they will be whatever I have made them. I suspect I’ve corrected the circuit and pcb in such a way that they are back on top in order to avoid breaking my brain completely in solving the issue on the board.
Welcome to software engineering, it is like solving a crime except you are the investigator in your own murder.
Part of what makes it so interesting!
A wild update appears! After a brief pause while I had some virus or other and was busy playing “hayfever or ill?” I got back to work on the amp today. I got to the point of testing and the amp does work… however how well it works is hard to say as I realized my ghetto diy dual rail bench psu is the worst! So I need to sort that. Meantime I am now trying to work out which led arrangement I actually ended up with! So that will keep me busy for a day or two. With a little luck I can do a proper test next week.
hadn’t realized the slang use of the word had crossed the pond, or are you a vanguard of american slang in the EU?
Oh it’s been in use in the UK with that meaning for quite a while. UK and US slang cross in both directions loads more than we notice. Particularly US to UK English in modern times because of TV shows and film. It’s generational though, US shows only really started showing up a lot in the 80s.
We can all thank the addition of Channel 4 for that, it was cheap programming.
Maybe? Dallas was the one I remember being on in the mid 80s, on BBC. As a kid it seemed like all the adults were a little obsessed by it lol
Nothing worse than questionable test gear.
I’m going to have to get either a couple of cheaper bench psus to put in series or a dual channel one. I can’t really afford a linear power supply and I am not sure if that matters. The single rail lab psu I have is linear but obviously it is the only one of it I have and I can’t get a matching unit anymore. I have some research to do there!
In testing news, I have now established that the fixed front panel pcb is designed for under slung leds so a little soldering to do and I think I am ready for some final testing if I can work out the bench psu situation. So close!
IME they are all pretty much junk for Audio work, they have a fair ammount of switching noise at higher frequencies that’s not well filtered, and many of them have measurable ripple under higher loads. I have 3 bought at different points, and the quality varies between he 3.
You can sort of work around it to a point, by adding filters on the output, but it’s easier to just live with it, and just know they aren’t the be all and end all of quality. I’ve only ever really resorted to external filters when using a buck converter to get 200V.
Having said all of that, while the overall quality of reproduction is clearly different, I’d be hard pressed to look at a 1KHz input signal into a scope and tell the difference on the output between the lab PSU and something good, so they are “fine” for most of the measurement work I do.
So much of the final “quality” is as much down to layout as PSU quality, I’m not sure how much ot matters when testing out of the box anyway.
Great advice and info, thank you.
The technology really does not matter. Check the spec sheet for the numbers you care about (peak-peak ripple, line and load regulation, setting precision, maybe read-back accuracy).
For the price class and work you do here, linear regulation has the advantage of starting from a lower noise floor. Issue is a big transformer is heavy and expensive making for a more expensive PSU.
A few “should do the trick”-PSUs:
  • Siglent SPD3303X
  • GWInstek GPE-2323A
  • Rigol DPP822
Yes, everyone would love a Keithley 2600B-series or R&S NGP800-series, we just have to come to terms that not every project warrants the big-boy/girl equipment class.
There is however, nothing worse than fault-finding your test gear.
That’s super helpful. The linear ones look to be beyond my budget for something I will only occasionally use but I think you’ve given me some good guidelines to go by. Thanks!
Having survived the recent ridiculous heat I was able to consider doing warm things again, like soldering. So I found a good budget dual rail bench power supply at a good supplier aaaand… out of stock until the second half of August. So I think I shall switch to my summer projects and continue this in September. Apologies for the lack of updates but this is a pause, not a fizzle!
