Radu Tarta Thread, Shiny Eyes / Simple Pleasure / Custom Builds
Thank you
Here are some pictures of the Radu 4P1L by itself, and with the PB MK2 and Taurus DAC. My Deluxe DAC is currently being modified for the GLD Deluxe Streamer that accompanies it. I was sent one as a gift for writing a letter on the owners behalf to the visa board. A welcome and very generous $7000 gift. It arrived today, but I won’t take it out of the box until my DAC arrives home with the proprietary optical module that will allow me to use that connection on the Deluxe and I2S on the Taurus, which is how I have it currently set up through my Roon Rock and Roon Streamer. I don’t feel a need to have another streamer, although it is supposed to be amazing. I have my system dialed in, so I am nervous how the GLD will add to the synergy of my system. But I am trusting the owner of Cen.Grand who is brilliant and says it is the best thing he has built. Which is saying something as the Deluxe DAC is extraordinary. I miss it already. Fortunately the Taurus is an amazing R2R DAC and my system isn’t really missing anything. Just one less end point until it arrives.
You know that is a chonker of an amp when that particular knob and outputs are just dwarfed by the rest of the build.
Do you have special feet on there?
This is a beautiful piece of gear, the rounded corners is a nice touch along with the signature Bakelite knob!
I see two sets of RCA jacks, is that for 2 inputs or is the second for pre-amp duties?
@geoffalter11 , so very happy for you, congratulations on the beautiful pieces :pinched_fingers: Your timing was coincidental, as i was reading about your 4p1L amplifier i was busy getting ahold of one of Radu Tarta’s 4p1L pre-amplifiers. I’m the third owner i believe, and not sure on its build date, the previous owner did send it in for some upgrades so i took the opportunity to snatch the piece up for myself, curious about the character it’s capable of adding to the chain.
The 4P1L is a Russian direct heated Pentode, Radu has designed this pre to use the tube in triode mode focusing on the linearity and tonality the tube is known for. Because of the microphonic nature of these tubes extra damping is evident throughout the build which works well in my unit. I get a tube ringing noise upon start-up that can come through the speakers, it goes away after a minute or 2 and is more affected by the amount of tube based pieces in the system, the more solid state the less chances of it :man_shrugging:. I also need to get the unit on my bench eventually and apply some De-Oxit cleaning and protectant to the interior, this stuff works well and is worth the time and effort to revitalize your electronics. The unit has a 2 stage warm up process in order to protect against noises and such so i don’t bother it for a full 15 minutes after power-up, i see no point in pushing my fate, thus i just leave things alone for that first quarter hour.
My initial impressions are as varied as the wildly different pieces I’ve mated while trying to gain experience w/ this unique pre-amplifier and i need to take notes for myself so i can remember…
Using only Charney Audio Companion Excalibur speakers w/ 2025 Lowther DX65 drivers.
Low end bass clarity, tightness and weight; my smaller listening room has chest thumping low end, it’s tight and extremely well imaged. The 108ā€ long horn design of the speaker cabinets works nicely as designed and I blend REL T7/X subs for the added spatial depth and bottom octave fill. Thus far the Radu 4P1L based pre has done an admirable job w/ a variety of amplifiers maintaining great low end weight. Volume control is consistent, albeit a touch noisy (hopefully a good shot of de-oxit will minimize this further). Consistent low end control thus far has been exhibited using my Yamamoto A80-S, Decware 341.5, Line Magnetic 218ia and First Watt Sit3, i’m excited to try a few more amps when the time allows but thus far my impressions of the low end capabilities of these Russian 4P1L’s running in triode mode is absolutely favorable. I have NOT experienced any flabby, loose, thick or overly soft low end bass character :pinched_fingers:
Top end using various DAC’s; the 4P1L’s don’t hold back in their top end prowess and if you are a fan of a clean, etched, detailed and well pronounced top end this tube is for you. There seems to be genuine character pronounced in the upper echelons of the frequency range. My Lowther drivers do need taming in this region once in a while and I can’t imagine what a variety of high end tweeters known for their extremely resolving nature will do when presented w/ so much resolution.
-My Sonett Pasithea DAC sounded incredible but some particular songs were too much for me at times. The level of overall resolution this DAC and pre combo is capable of has been intense. :flexed_biceps:
-Similar experiences w/ my Lampizator Baltic 3 but i noticed a bit more in the lower registers of the upper frequencies. I’ve not had the time but this is where some tube rolling can really lead to a well blended group of components tuned to your exact pleasure :pinched_fingers:
-In comes the surprise heavy hitter DAC :flushed_face: the Line Magnetic LM-32, bam! we have an easy character synergy match, no extra effort needed. The slightly warmer richer texture and capability of this DAC when running in tube mode are the Yin to the Yang of the 4P1L tubes. Nice :heart:
There will be more information i want to capture for myself, I simply forget if i don’t write things down :zany_face: I’m generally a fan of DHT tubes, the Russian 4p1l driven in this fashion is new to me, i’m still learning, experimenting and experiencing. I don’t think this Radu design is some kind of neutral, transparent design built to pass signal and attenuate volume from one piece through to another. This a a tube based line stage w/ character and gain and probably a few other characteristics i’m not technically proficient to speak to. My music playback has character and I’m enjoying it all :hugs:
Thank you for your response. I spoke to Radu the other day, and he wants to build a 4P1L that mimics mine now as I have found a certain synergy with tubes that makes this amp as he stated ā€œmore holographic than he ever imaginedā€. I also agree that NOS/R2R DACs can be a bit much for the amp and almost becomes to much of a good thing. I use the Hegel HD30 and its incredibly quiet and clean nature while still having zero etch, peaks or nodes makes it the perfect compliment to Radu’s amp. He does love this tube configuration and mixed with Lundahl Amorphous Core Transformers gives the amp as he calls it ā€œthe right component and design synergyā€ and then I have found the right compliment of tubes to match that design and component synergy. I use a pair of Sovtek 1965 inverted c cup 4P1L’s that are cryo’d and sound exquisite, a 6H30P-DR and a pair of 6CJ3 Sylvania NOS rectifiers from the 1950’s. All told I spent $300 for the 7 tubes. Only because the DR was expensive. Radu believes that I found the perfect synergy of tubes for the design and now he wants the exact same amp with the same build and tubes. I also love that he has used the Pentode in triode mode and the amp sounds more DHT than many many DHT amps I’ve heard. I love the character of the amp. The way it sets a deep pocket and how the midrange instruments image like a halo above the pocket. How it spreads out to all 4 corners of the frequency and I feel like sounds jet at me from all angles.
Thank you for your experience and for your DAC experimentation. I have experimented with 3 DACs and have found the best synergy with the Hegel. I have also tried the Musician Taurus which I absolutely love and has a permanent home with my EC Aficionado and CFA3, which benefit from its timbre and macro capabilities. I also have a Cen.Grand DSD Deluxe DAC and while it sounds wonderful with the 4P1L, it is a bit too polite as is DSD to my ears. According to Radu, the key to his design is that all of his designs are 2nd order dominant and he tries to keep all other harmonics as far away as possible from the 2nd order leading to a very clean and transparent sound. Something I definitely hear. I am definitely in the Radu got it right camp. Thank you for your thoughts, they are wonderful.
Mine is from 1958.
Yes, special feet. Not exactly sure what they are. I am not strong enough with my illness to lift them up, but I think they are a version of isoacoustic feet.
Pre-amp duties… The back set is for the headamp, and the front pair is for the pre-amp, which I would assume is wonderful, I just haven’t tried it in that configuration. I should though and see how it pairs with my other amps.
I have been listening to the Shiny 4P1L with the Hegel HD30 DAC and the results are nothing short of stunning. With the Atrium Open I have never heard this headphone sound so technically adept, which isn’t how I would describe this headphone. I find it the most enjoyable listen, but not the most technical headphone. However, the combination of the Hegel and 4P1L is truly a magnificent pairing. The incredible depth, dark background and evocative musicality of the Hegel paired with the Shiny brings so much air, ambience and breath around every instrument and such incredible emotion. I am truly lucky to have this amp and have found the exact right pairing of tubes to give it more of a holographic sound while providing the tone/timbre that makes music sound like music and there is a transparency and organic nature that I am finding so alluring. So much so Radu reached out to me about building another for himself with the same tube configuration I have put into the amp. I just got lucky and found some 1965 4P1L inverted c cups that in combination with the 6H30P-DR and a pair of 1950’s 6CJ3’s has given this amp wonderful synergy. I have never used it as a pre-amp which I need to try, I just don’t have any speakers, so I would need to run it as a pre-amp into my CFA3 or Pure BiPolar MK2 which is easiest enough. This amp is more DHT sounding than any DHT amp I’ve heard or owned. Radu did quite well pairing the right components with the perfect design and has created what feels to my ears like a masterpiece.
Being new to this site, is there a place where I can list a couple of high end products for sale? I have a Cen.Grand DSDAC Deluxe ($6800 msrp) and the new Cen.Grand GLD Deluxe Streamer with a proprietary module that completely eliminates the use of USB and jitter from the device. They sound amazing. The Streamer is also ($6800 msrp). I am willing to sell them together or separate, but don’t know where to put them in the site so I am not spamming this thread. Any help would be appreciated. They are both basically new, and work perfectly. I just prefer PCM to DSD, and would like to go a different direction. They are meant to go together, but the streamer can be used with other DACs. I have tested it with 2 different DACs at the same time plugged into the streamer. One BNC, and the other via I2S on the module of the streamer and the sound is sensational. The Streamer is truly magnificent. Any help would be greatly appreciated in getting to the right place. Thanks.
You should be able to create your own sale thread no problem, I believe
Try this section of the forum, i think newer members can see it: https://forum.sonusapparatus.com/c/buy-sell/12
Thanks for the help. I have decided not to sell them at this time. I absolutely love the streamer and while DSD isn’t my favorite codec, the Deluxe with the GLD is a very powerful and informative combo. I really don’t have a need to sell things that sound as good as they do. And I am in utter shock at how slow things are moving everywhere. Nothing is moving! There has been a DNA Stellaris for sale for a month now on head-fi. That amp would generally sell in hours. It is crazy how few things are actually moving.
I love your impressions. Thank you for posting them, and I am sorry it has taken me awhile to respond. I always forget to come here. I agree with you that the 4P1L is a masterful tube when used the way Radu is using it by bypassing 2 of the 5 electrodes creating a DHT sound. A sound that with my Taurus R2R, or my Hegel HD30 provides a black hole of depth and incredibly insightful music. Radu is very 2nd order dominant with all of his designs trying to keep all other harmonics as far away as possible. I think that causes what you are hearing, with a level of resolution that can be startling at times and intense. I find that the way he has designed the 4P1L, he has created a DHT sound that has the romantic nature of a midrange 300B, and the treble nuance from the finest 2A3 tubes. Couple that with supreme control over harmonics and you get an amp that has incredible bandwidth, dynamics, and subtlety. I feel like the amp sets this gigantic pocket and then all of the melody just floats like a halo over the pocket coming at you from all angles. At first I found it to be almost too much at times as it is so resolving and full of information, but now I have become accustomed to the sound and I am addicted to the Radu house sound.
I haven’t used mine as a pre-amp which it can act as, only as a headphone amp. However, I know that he has built your pre-amp and my headphone amp with very similar specs. He likes this tube combo with Lundahl Amorphous Core Transformers and a TKD volume attenuator. I have yet to get any noise from my TKD, and I also agree that the amp sounds best after about 15-20 minutes to fully bias. The only amp I have that doesn’t need 15-20 minutes to fully bias is my Mjolnir Pure BiPolar MK2, which has a servo and the amp is basically at full strenth instantly. Thank you for your amazing impressions. I have also never had a DHT amp that doesn’t have any DHT tubes. The one thing I highly recommend is a 6H30P-DR for the driver slot. That tube is amazing. I was also lucky and found a pair of 1965 inverted c cup 4P1L’s and the guy was so nice that he sent me two sets. Both cryo’d, which apparently drops the voltage by 15% which helps to ensure the amp stays biased at 170 millieamps. I hope your continued enjoyment has only increased.
Hello, new here. Some of you may know me from head-fi where I (largely) unsuccessfully setup a Shiny Eyes amp discussion thread.@geoffalter11 kindly invited me here where the conversation seems more active. I acquired one of Radu’s amps several months ago thanks in part to Geoff’s rave reviews of his 4P1L. Having desired a full sized 45-based head amp ever since I heard the diminutive Andix Audio HPA-45 and generally wanting to explore the ā€œless is moreā€ wattage path, I sold my 300B amp and commissioned Radu to build a 45 combo headphone / speaker amp. The amp leverages his Shiny Eyes platform seen in his 300B designs (e.g. C3g input tubes, Hashimoto iron, etc. but uses a 5AR4 rectifier). Outputs 2W max from the 8 ohm speaker taps which I use to drive a Raal Immanis. Headphone sockets are outputting at 16 ohms. I’m a habitual NOS tube roller so I have RCA Radiotron globes installed currently. The amp delivers a truly engaging listening experience and I agree very much with Geoff’s comments about second-order harmonic emphasis and wraparound staging being very much part of Radu’s house sound.
Welcome to the nut farm! I believe you will find much in common with other members.
Hi @ardbeg1975 , i think i spoke to you once or twice on headfi over the years. I am glad you made it to this part of the woods.
I feel like you dont get 5ar4 rectifiers on 45 output tubes a lot. I know a lot of amps that do 45/2a3s will not allow them when switched to using 45s.
Tube rectifiers drop a lot of voltages, and 5AR4’s drop less voltage than say a 5U4G.
45’s already support less peak voltage that 2A3’s so given 2A3’s tend to sound better close to there voltage limit, any amp designed for both is probably at or very close to the 45 voltage limit, and swapping to a 5AR4 probably pushes it over.
In the end tube rectifiers are just Diodes, with some (often large) voltage drop across them, you can design for almost anything. You can even use triodes as rectifiers if you want, it was somewhat common to use triodes as rectifiers for higher voltages, there’s a box I can’t remember the name of that plugs into a standard 5U4 rectifier socket and lets you run a pair of 300B’s as a rectifier, some people swear by them, there’s is nothing in the box but a filament supply and some wiring.
I dont recall the name either but i know the WhatsBest forum lampi crew uses them.
That is what i figured about 45s and 5ar4 rectis, they would be too much. But if its built for it then why not.
