This is true ![]()
Isnt exfat supposed to be compatible with fat32? Or is that just on the reader/dap side?
They aren’t compatible, exFat is generally considered better, but it was a proprietary MS format for the longest time.
Gotta love clicking all music and your dap tries to update the media library…
Lolz. Is that a problem with your Dap in particular? Or something you noticed before the infamous coffee incident of '22?
Because I have heard continously about quirks with the Dap but I can’t say I’ve noticed any myself.
It’s apparently a quirk of the P6P’s software as I think @Towa mentioned once that it was to do with the length of track/folder names? I’ve never got round to properly arranging my library on my server as I was having issues with my main PC and never got round to rebuilding it before the baby came ![]()
Ohhhhhhh right, I actually read through this thread to get hype whne I bought the DAP. And I do remember seeing that! Super interesting ![]()
I just don’t try to index the whole 1TB card. It still lets you scroll folders.
Yeah just sometimes I forget and have to either sit through it failing to index or force it to turn off ![]()
Has anyone else noticed their P6P (in USB mode, not sure about direct) getting interference at all? I noticed mine is a bit susceptible to it and I can really hear it when nothing is playing, especially through my speaker setup. I can get it to go away if I cover it with my hand but I’ve not found anything else that seems to stop it so far.
I have never had yhis be any kind of issue. I even lay my phonr on top of my p6p for most use
That edit
It’s totally his slipper…
Hopefully it’s just my unit (as much as it is annoying for me)
So Ive heard the TI is slightly above but the LP6 (gold/plat) is maybe even a step below P6P, but at best the same level. I think thats why I was so shocked to find out I have a strong preference for it over P6P tbh.
Yes! Sus on P6P is shockingly natural and vocals are simply sublime. I do think its an acoustic only kind of experience though, and It wasnt crazy happy with complex tracks either.
Thats really interesting. TBH I dont read much talking about the P6P flavor, but IMO its quite strong. Like strong to the point of being (completely different than but) the same level of heavy handiness as holo stuff. Other than the classic NOS roll off, I personaly think the heaviest of the flavor comes into how exactly it stages with that very intimate, deep, and laser focused imaging (but less info in between images than it realistic imo). Its an utter champ at acoustic and realistic vocal density, but falls behind for other genres that I feel more neutral sources have less issues with. TBH, I think my ideal would be to keep the P6P and get an LP6Ti but I simply am not the kind of guy to use more than one portable chain so it makes no sense to do that.
It will be inline with the LP6. L&P says that they try and keep the tuning of the two lines separate and coherent, so LP7 will be a direct upgrade to LP6Ti and LP7Ti will be an upgrade to LP7 (all with the same general tuning)
That is at least on the road map but I dont think its expected for at least a year after LP7 finally drops.
Just want to bitch once again about how much worse USB input is than local files. Anyone tried using a good USB source/cable to fix this? the cheapo isolator I had did help some but it wasnt enough tbh.
Also, LP7 wont be released until second half of 2023 at the earliest according to musictek. TBH, with that kind fo time line, I may try and get an LP6/LP6 Ti (7ae is out of reach for now)
Makes me sad ![]()
anyone know if the SPDIF out on the P6P is optical/coax/what? Trying to figure out what cable I need to play with it.
I’m assuming it’s SPDIF-COAXIAL, but you can probably verify by putting it in SPDIF out and if there’s no red light assume it is COAXIAL.
