That is some gorgeous purple heart. It’s such a deep red wine color and I am very jealous.
I use ZMF Ori cowhide pads with attenuation rings on my X00s with bubinga chambers and I feel like this give more bass than the stock X00 pads while also having a more open stage. I don’t know if they’ll act the same on a TH900 but I think the better comfort and potential sound upgrade are worth a shot.
ZMF pads are totally worth it the problem (big ass problem btw) is knowing which one you want because there are so many and the small changes in comfort and sound between them make a huge difference
The pads quality is kilometers ahead dekoni, and every other aftermarket pad brand I have tried, except yaxi which also get a pass.
Ori pads which are the smallest end up fitting most headphones, the backside is quite elastic and doesnt feel like it will break or damage by being tight, mine hasnt.
The Lawton pads are probably the brightest pads I still like. They have a more “neutral” sound compared to most of the other pads I’ve liked.
Having gone from the stock X00 purple heart cups to Lawton’s bubinga chambers (type 4 wood) I feel makes the highs a non-issue unless you are actually sensitive to highs. Nothing feels harsh or too sharp. The cowhide pads also help a bit but the main improvement is the Lawton chambers.
It’s also worth pointing out that the Ori cowhide pads are also great even without attenuation rings if you don’t want that B A S S
Cowhide tends to be the darkest sounding material, but that is only in regards to ZMF’s own headphones as not every headphone will react the same way to pad changes.
On my Lawton modded X00s the Ori cowhide pads are warm and bassy, but the highs are not significantly reduced compared to the lambskin or suede/lambskin hybrid ori pads I have.
Also I use the cowhide pads with attenuation rings that result in some rather stupendous B A S S, but without these attenuation rings the bass is much more reasonable for most people’s tastes. Usually with the X00s many pads sound a bit thin without attenuation rings but the cowhide Ori pads still sound great imo (as do the other two Ori pads I’ve tried, but the cowhide pads are the best of the three w/o attenuation rings).
After spending some time swapping between X00, stock (TH900) and Lawton angle pads, I think the stock pads are a good middle ground. Will be leaving the cup dampening out still.
Ty, im gonna consider this one over the ZMF one it looks very nice, I was probably going to get some pads from ZMF anyway to combine shpping, but I’ll consider both options.
Also If anyone thinks the copilot is better for a denon/grado headband than the regular pilot pls let me know.
Are you in Europe? If so, also look at Shipibo audio. They make great headbands (as well as metal gimbals and rod blocks) and are based in Poland so shipping shouldn’t be bad. This is also a good option if you want the nicest cheep option.
As for fostex headbands, I like this one since it’s still looks nice, fits snuggly, and adds a bit extra padding.
