First off, big disclaimer, this is just for fun. The discussion below is 100% non-scientific, completely made up, and the result of drinking and bullshiting with other audio nerds. So use at your own risk, and hopefully have some fun ![]()
With that said… what is the definition of a portable HiFi system?
Is anything than can run on batteries portable? Is it defined by size (ie pocketable), features, connectivity? Some exceptionally creative listeners have found ways to use battery packs to power small desktop devices on-the-go. Does this make it “portable”? What if I put a diesel generator in a wagon and power a full tube DAC and amp from it? Is that “portable”?
We all have collections of cell phones, iPods, DAPs, IEMs (with and without wires), headphones (with and without wires), DACs (some that dangle and some that dongle), Amplifiers, and speakers. Not to mention battery packs, DC/AC power inverters, AC/DC power rectifiers, and god help you if you use a diesel generator.
To help clarify this deeply troubling and all-important question for our community, the concept of “transportable” has started being used. If a setup can be moved for away from home listening, then it’s “transportable”. But where is the line then between “portable” and “transportable”?
side note:
Regarding the line between “transportable” and “stationary”, I put this line at the need for AC power from a wall. This will always tether you to the longest extension cord you have. If you have an AC cord long enough, go for it. But you really are stationary if you have a leash tethering you.
I subjectively think of “portable” as something I can listen to while moving around: walking, running, moving about in some way. Everything is in a pocket or in an ear. “Transportable” is a step up from this where it is still battery powered but requires a place to set it down. It’s too complex to live in my pockets. This is clearly a personal thing - some of us have tighter pants than others - so the amount of pocket space varies. But appropriateness of apparel aside, this is how I subjectively view it.
Now, if I’ve learned anything from the internet, subjectivism isn’t acceptable. Everything MUST be objectively defined. Or else you get yelled at on forums. So to avoid the yelling, bringing world peace to us all, I would like to help define an objective measure to clarify what is portable and what is transportable.
The measurement I have defined for us is the “Mobility Factor” (or “MF”). It is a point system for your setup, that you add up to achieve a total score, or Mobility Factor. The unit of Mobility Factor is “complexity”. So for example, a system will have a Mobility Factor of 3 complexity. (Comparing to a similarly useful measurement, SINAD is measured in units of dB. Mobility factor is measured in units of complexity.) The point system is as follows:
- 1 point for every battery
- 1 point for every wired connection
I have arbitrarily conclusively decided:
- MF <= 3 Complexity: portable
- MF > 3 Complexity: transportable
Examples
With this cosmic constant now rigorously defined, let’s look at a few examples:
- AM/FM wireless headphones: 1 battery, 0 wires → MF=1 → portable
- Cell phone playing out speaker: 1 battery, 0 wires → MF=1 → portable
- Cell phone with wired IEMs: 1 battery, 1 wire → MF=2 → portable
- Cell phone with wireless IEMs: 2 battery, 0 wires → MF=2 → portable
(I’ve semi-arbitrarily decided wireless IEMs count as 1 battery in the charging case, since that is the thing that is charged.) - Cell phone with wired dongle DAC and IEMs: 1 battery, 2 wires → MF=3 → portable
You get the idea…
Now looking at some interesting specific products, so I can look down my nose of superior scientific rigor and judge them as portable or transportable:
Chord Mojo:
Cell Phone + USB into Mojo + wired IEMs: 2 batteries, 2 wires → MF=4 → transportable (sorry Mojo, you are just too MF complex to use as portable, you are hereby judged transportable)
BUT
Mojo + Poly (with SD card storage) + wired IEMs: 2 battery, 1 wire → MF=3 → portable (redemption!)
Cell phone + Mojo + Poly + wired IEMs: 3 battery, 1 wire → MF=4 → transportable (sorry, just too many batteries to keep charged and things to carry around for this to be properly portable)
So, if Mojo wants to use the term portable, it must be in conjunction with the Poly and an SD Card. Otherwise, it is henceforth transportable.
Chord Hugo:
Cell Phone + USB into Hugo + wired IEMs: 2 batteries, 2 wires → MF=4 → transportable (no surprise)
BUT
Cell Phone + Bluetooth into Hugo + wired IEMs: 2 batteries, 1 wire → MF=3 → portable (Hugo can be standalone portable, but Mojo cannot)
Hugo + 2Go (w/ SD Card) + wired IEMs: 2 batteries, 1 wire → MF=3 → portable (just kinda big)
Hugo is actually MORE portable than Mojo because it supports bluetooth without an extra adapter!
A more extreme example, Schiit Fulla
Schiit Fulla + 5V Battery Pack + USB Power Cable + Cell Phone + USB Data Cable + IEMs: 2 battery, 3 cables → MF=5 (transportable)
I think this makes sense. It can be run this way while sitting on a long flight or some place away from AC power. Making it a “useful” transportable setup. But it is more MF complex than using a Mojo or Hugo.
So if you want to go audiophile wild, fine. you are hereby dubbed “transportable” with your battery pack. But try to keep the MF complexity < 6, for your own good!
Conclusions
If you have read this far, well done!
And if you have correctly ascertained that I created this whole thing to make a point about the Chord Mojo not being portable, good for you! That’s correct! I’ve always thought the Chord Mojo was too unwieldy to be truly portable. It’s a nice device, but it’s good for transportable setups (listening on long flights, in the office, etc). Not for walking around. I would rather use a Hugo2 for walking around, via Bluetooth.
Personal crusades aside, I do think the Mobility Factor is interesting. It does draw lines in places that match my experience: dongle DACs are reasonably portable and usable. If there are too many battery powered things involved, it becomes a pain to keep them all charged. You can get a battery pack for your Schiit Fulla (or other low power desktop device) and be transportable.
Hope you enjoyed this!
