General Electrostatic Thread
Thought it’d be worth making this thread as Electrostatic headphones/systems are coming out increasingly more and often from unsuspecting places. ES Labs, Hongshu, and SJY have released some of the latest, but there will be more and hopefully we see more electrostatic amps/energizers.
_
Starting this thread off with impressions of the Hongshu EH-1.
One caveat first. The bundled amp, the EHA-1, holds it back in general, but by far the worst offender is actually the stock power supply. It’s a dinky thing with a super thin wire that I don’t think I’d use on my router, much less the amp that drives my headphones. The system is a lot less listenable with it, with hash-ey treble, weak deep bass that clips, actual wobble on heavy tracks and a lot more grain than there should be. It’s labeled as being able to do 1 amp, but I’d bet that if you’d measure it under load, it might not even be able to do that, besides other issues that would probably show up. In short order, I switched it with the Ifi iPowerX 12V and that’s what my further impressions are based off.
The EH-1 is surprisingly well-rounded on initial listen. Extension is good in both directions with a fair amount of sub-bass, which is pretty robust and slammy. The overall bass level is not as present as dynamics or better planars, but when the track needs heft and a hard impact, it delivers well. The bass reminds me a lot of a well-driven planar, with similar levels of tactility and even more speed and punch higher in the bass. That’s especially the case as you go higher up as well, with a good amount of meat on the bones and engagement through the upper bass. Lower midrange is forward and presents itself somewhat as a slight haze over voices and much of the midrange, but it’s not bad enough to be a real weakness, and makes up for it by being very neutral as you go up with a lot of resolution, decent timbre and little to no sibilance. It’s very even and controlled in the upper midrange and lower treble and that results in surprisingly smooth and fatigue-free listens, but without going oversmooth and losing all of the airy, breathy quality that E-Stats are known to have.
It’s capable on the spatial front. Lots of depth to the stage, reminding me a little of an HE6 style presentation where it’s similarly deep to wide and very, very cohesive. It surpasses most planars I’ve heard in this sense, the scale and holography are excellent. Stage size is also up there to my mind, wider and deeper than an HE6 with the stock grills, but probably losing out on height a bit and especially losing out on height to an egg-shaped Hifiman. Also wouldn’t say that it lacks grand-ness and it’s more of a grand and larger presentation than not for sure, but Hifiman egg-shapes were built for that and they push that aspect well further.
Weaknesses lie in the finer aspects and refinement. It’s a continuously energetic listen and there’s nearly no liquidity and a diminished kind of decay. It reminds me of an IEM’s kind of timing, which is clean and clear, but kind of stiff and cut-off/short. Gradations similarly have the same problem, especially as you look further to the ends of the FR, and while treble can be sharp, dynamic and fast and bass pretty juicy, there isn’t much in the way of shimmer or linger. Again, I think it’s the amp’s fault for the most part. Better power supplies helped mostly get rid of the more serious problems that the amp had with the stock PS. Going up to an Ifi Elite from the X pushes refinement only incrementally, but at least it does something in stage and image size, bass quality, smoothness and a touch more slam. I don’t have any previous experience with Electrostats, but for planars, most of the weaknesses of this system as it is are helped or even entirely changed by going to heavier and higher quality amplification. The power supply differences do indicate to me that it has at least a moderate ability to scale, and I did notice that changes within the chain showed themselves starkly through, like changing DACs, Op-Amps and some power stuff I’ve been playing with. Which kind of makes me realize that it’s a very resolving and textured headphone, at least in the way it can be right now with the bundled amp.
Almost forgot to mention the build lol. It’s light, kind of thin and bordering on feeling cheap but it’s still solid and almost entirely made of metal. Fit is great, it’s a little on the clampy side, but the suspension strap is well-shaped and pretty long, so this headphone fits my tall head nicely. It’s far more comfortable than the headband system on the Sundara/Ananda and with the extra perk that there’s little to no creaking. Pads are also replaceable without issue and seal well.
So, first E-Stat. After being used to dozens of planars and dynamics, it overall sounded a lot more normal than I expected. Some of its sheer capabilities go pretty far up, like control on the macro, cohesive-ness and speed, to the point where it’s reaching HE1000 level to my mind. The question now is more about how much the rest can scale, so I have a second-hand Topping EHA 5 is coming in. Might add a little about it here if it’s significant. I’m also thinking of doing a review on Head-Fi within the month, as I think it’s worth spreading the some of the peculiarities of the system before people’s opinions of it settle.
Thanks for the review, it’s very helpful.
l’ve wondered about this after reading several other impressions and a review on headphones.com, which I always take with a giant sized grain of salt.
I nearly pulled the trigger on this over the last few weeks, mostly because it’s cheap and I’ve never had an electrostatic headphone.
Your description makes me glad I didn’t, I think I’d find it briefly interesting but then regret having bought it! :laughing: So thank you for your public service. :wink:
If you’re willing to get a real energizer of some kind that doesn’t run out of steam and aren’t scared of some mild EQ, I think they’re the best price to performance headphone on the market. It’s a shame you’re forced to pay for the stock energizer.
Can’t account for preference, but I think the value is very high regardless. At the same time, yeah I was thinking that less people would be receptive to it here because here there’s more interest in things being balanced and refined.
Like Pokrog says, if you can swing for a better energizer, it seems worth it. Although that’d be an E-Stat amp/energizer that’d cost ~$1K. That Stax I put in the Used Deals thread would probably do a fair job, for example. But damn, there really needs to be like a Jotunheim/Asgard kind of example of an E-Stat amp that pushes the quality and value further while giving a lot more people an option. At the moment, it’s largely entry level or portable amps that don’t do better sets justice, or the high end stuff starting at like $2K, and all the Stax amps hovering $1K and up are not really known for their value.
