@ckhirnigs wanted to move this here…
The bliss obviously has more power. MJ will be fine for most headphones outside the Sus and HE6.
Clarity is very close. It could go either way. Bliss can sometimes be a little smoothed over, so at times I think this can make the MJ seem a little better here. This is more obvious with things like vocals.
Stage probably goes to the bliss. I think it has more area to work with in the stage. The image presentation may be a tad bigger. But I would say neither of these areas kills the mjolnir. It still carries its own weight here. I don’t have an issue with the stage and this is someone who likes the HD800S and stage. Stage depth is probably a tie. It’s very close in this area.
Detail retrieval, I’d say a tie. Again, it’s not killing the mjolnir. Sometimes when I would use the MJ I could hear things that I typically didn’t pick up on with other amps, including the Bliss. So I would go back to the Bliss to see if I could hear it. I could, but there was something about how the MJ handled this. It pulls out those micro details so well but also so authentic/naturally/more analog lol? And the edge of notes is so vivid and defined with the MJ. Basically no complaints here.
Bass, I actually like the way the MJ does this. Outside of using the Sus, I don’t need a mid bass bump. The MJ hits hard/has nice impact, goes low, has a nice weight to it, and I think I may even like the texture more.
Vocals, could go either way. No complaints.
Layering, the Bliss may do this a touch better depending on the recording but the MJ isn’t bad. I think the stage of the bliss and the area that it has to work with may help this. But I don’t hear anything with the MJ and get turned off by it. It’s not like things become mush and it doesn’t stay coherent.
MJ has really good transients. This is a really good trait of this amp. Bliss is good too but I think its smoothness can hurt this area at times. MJ wins here for me. I think it’s clarity helps.
Just some quick comparisons. If you have any more questions, I’ll do my best to help. This can be tough for me lol. Me try hard
And I’d say forget what others say. Gotta try it on your own chain, with your headphones. You like what you like and don’t change or settle because someone else, you won’t be happy.
