I can only speak to my experience with the same tubes in my Pendant or Nautilus amps. Also, I tend to use 12au7, but they should have the same same “house” sound as the 12ax7.
The one Mullard 12au7 I tried had an amazing bass and very rich mids, but I found the highs were rolled off. Bob Marley sounded out of this world, but unfortunately I couldn’t use the tube for general listening. On the other hand, the Mullard EZ81 rectifier is my favorite rectifier in my Pendant, with very clean, neutral sound.
I’ve tried Tungsram 12au7 and EL84 tubes and found them to be very musical but they were a little lean-sounding (i.e. bass-light) for my taste. Bear in mind that I like my tubes to be warm of neutral, so factor that in when I say I like or dislike a tube. The Tungsram were probably neutral.
Amperex and Brimar are my sweet spot, as they tend to be full range (no roll off) and give me a little extra warmth in the mids. I’ve found the cheaper Brimars (e.g. the 1970’s CV4034 from Tubemonger) to have a bass boost, actually more bass than I want, whereas the more expensive ones (e.g. F6067T and 1950’s Footscray CV4034) are closer to neutral. I’m currently using a Brimar premium 12au7’s in both my Pendant and Nautilus, Amperex EL84 and Mullard rectifier in my Pendant.
In addition to Brent Jessee’s site that @Deleeh mentioned, I also use Tube Maze a lot to try to get an idea of a manufacturer’s house sound, even if they aren’t reviewing the same tube.
Also, since the Quicksilver and Pendant use some of the same tubes, I’d recommend reading the Pendant tube rolling thread in the headfi forum, particularly by Wes, who is addicted to trying out new tubes. The tubes may not sound exactly exactly the same in the Quicksilver, but you’ll get an idea of the differences in sound between each brand. Wes likes absolute neutrality in his tubes, so keep that in mind when he writes about how fantastic or how terrible a particular tube is. If you have the same taste as him, then you’re golden. In my case, I like a bit more warmth, and I’ve actually bought a few of Wes’ castoffs that have become keepers for me, so it’s good to know what you like and what the reviewer likes.
