Decided to try LMS/Squeezebox today, got iPeng going on my iPhone, and the Material Skin for my desktop to control everything. Then since both streaming server services (Roon and LMS) were running on my m1 mac mini I did some A/B testing to see if I’d hear a difference. Keep in mind I only tried this test with my ZMF Auteur headphones since I’ve moved some things around and I’m waiting on a Zynsonix speaker amp box to come before I use my replacement Susvaras off my aegirs again.
Setup is M1 Mac Mini Roon Core/LMS > Network Switch > optical isolation with 2 ethernet to optical adapters > RPI 4 with RopieeeXL > SU6 > Amber 3 > Jotunheim 2
When doing this test I never touched the volume control and I used God of War by Bear McCreary as my first test track. The first difference I noticed is that LMS/Squeeze does a better job with sound staging and placement than Roon. Also as the track gets busier I noticed that Roon tends to sound flatter than LMS, with LMS doing a better job keeping everything where it “should” be in the track. Roon on other hand, due to its flatter sound can make certain instruments come forward more, which some may or may not like. But overall it seems that LMS handles the business of this track better than Roon does as far as sound quality/resolution goes.
The next track I tested was Rolled Up by Benny Sings. This one had its fair share of differences as well, but overall LMS just sounded more “correct” to me if that makes any sense. While Roon does do a good job with placement on this song, it seems to exaggerate certain things in the mix (like the sound of the birds at the beginning of the song), while this may be nice for picking things up in the mix, the placement of things (like the birds) just sounds more correct to me on LMS. Another thing I noticed was the voices seem to have slightly less definition to them on Roon vs on LMS. Bass also has slightly better resolution on LMS, but Roon bass does sound a little more forward than LMS.
As far as the interface goes, once I got iPeng customized to my liking on my iPhone I found myself enjoying it just as much as Roon’s interface (for local music). And with the iPeng playback addon, I could use it to play music through my iPhone just like Roon ARC (as long as I’m on my home network lol). So, for my use case so far (A single server to a single endpoint and sometimes my phone) I can see myself switching entirely over to LMS/Squeeze, and saving some money in the process. The downsides to LMS though are ease of use/installation, missing lyrics (album/artist info isn’t missing though with the “Music and Artist Information” plugin), worse integration with Qobuz (while there is a plugin to use Qobuz via LMS/Squeeze, the interface for it sucks compared to Roon.), Easy EQ settings for specific headphones, and no Roon radio where it will just start playing suggested music once you get to the end of a playlist or album. But despite all of those downsides, what LMS does well may just be enough for me to switch since Local Music playback is my primary use case anyways and I don’t mess with EQ.
I know I should probably take more time to test these two back and forth, but I just wanted to leave my first impressions here. So far though I am fairly impressed with LMS/Squeeze for local network music playback and if I switch over to it completely I’ll probably get rid of Qobuz as well (and use Spotify for music discovery), then I’d be saving money on two subscriptions while still having the functionality and sound quality that I care the most about.
Hope this helps anyone on the fence/considering trying out LMS/Squeeze coming from Roon.
