Feeling bored today (this ended up taking a lot longer than a day) and have some little free time (I was wrong), felt like doing some mental exercises (I guess?) and ended up making some curated pairings for the Utopia that I’d want to own myself (not including cost of the Utopia, used prices, limited to 4 dac options per pairing). Basically the top picks and setups I would make in that price bracket if I was buying for myself or for a friend. I tried to make these somewhat more equally balanced and not heavily focused on one side like dac or amp, but there could still be cases where you might want to do that so really depends. Not including cable, tube, or digital sources/streamers/transports/ddc/whatever costs since that’s something you can get into later on. Note that my preferences with these headphones is to improve upon and emphasize what they have with balance, rather than try and turn/tilt them into something they aren’t
under 3k total used
This range I think is a good place to start off for the headphones, yes you could go even lower, but I really wouldn’t suggest it, this is the range to me where I think the headphones actually become worthwhile over the clear.
Tube
Option 1: LTA MZ2 + LPS
A reasonably neutral slightly mid forward pairing that makes them very dynamically alive, a stage with a very black background and a smaller but very deep and spherical stage that works well with focal, pretty resolving for the price, bass that has decent control and tightness but not standout with more focus in the midrange and treble, forward overall and cleaner feeling, great extension, great separation, and great speed.
DACs:
Schiit Bifrost 2 (warmer neutral but a bit more relaxedness, weight, and width with slight macro focus)
Exogal Comet Plus* (slight lean into warmth and smoothness with holographic stage and micro focus)
MHDT Orchid (sweeter and richer lean into things, very organic without sacrificing technical ability)
Merason Frerot (see above but more balanced and technical with less immersive stage and dynamics)
*might be pushing price used
Option 2: Quicksilver Headphone Amp
Something that focuses more on being very spacious and holographic but still accurate and organic enough, more weighted but well balanced, very separated, a bit more of a microdynamic focus without being lacking in macro, resolution good but not stand out, and generally just a great all rounder with a more slight w signature that works well with most things.
DACs:
Soekris DAC2541 (reasonably neutral and balanced slightly cleaner and more focused leaning)
Chord Qutest (more on the clean side of things but fun despite that, stronger micro focus)
Option 3: Dragon IHA-1
Something leaning more overall clean and linear, very forward, very technical, somewhat no nonsense, pretty detailed, focus on coherency and linearity, wide stage with organic placement, very dynamically accurate, overall another good all rounder for a neutral and competent pairing
DACs:
Schiit Bifrost 2 (warmer neutral but a bit more relaxed, weight, and width with slight macro focus)
Holo Cyan PCM (stronger lean into warmth and smoothness with holographic stage and micro focus)
Solid State
Option 1: Violectric V281/280
A bit of a warmer and more relaxed leaning pairing but without sacrificing much energy or technical ability. A wider and more spacious stage but slightly more hazy placement, great tonal density, more of a microdynamic focus, great overall control, solid resolving power, great timbre, overall fairly organic and warmer leaning without sacrificing what makes the Utopia great.
DACs:
Soekris DAC2541 (reasonably neutral and balanced and more focused leaning)
Crane Song Solaris Quantum (warmer sweeter lean with more space and size, organic and technical)
Merason Frerot (a softer and more laidback lean without going too far, but pushing the line)
Option 2: Bryston BHA-1
Overall somewhat a middleground of the two others mentioned while offering more technical ability than both for the most part (equaling 281 but exceeding burson), a neutral warmer signature that’s forward, spacious, very well controlled and impactful, slight macro focus, overall pretty well balanced and capable.
DACs:
Crane Song Solaris Quantum (warmer sweeter lean with more organicness and technical ability)
Holo Cyan PCM (leaning more into space and grandness with more warmth and smoothness)
Option 3: Burson Solost 3XP + Supercharger
A focus more on control, command, impact and slam, and overall linearity without being harsh or overdone, slightly smooth, forward without being overdone, strong macro focus. Stage isn’t that big but accurate, resolution is great, speed and separation is strong, energetic.
DACs:
Schiit Gumby A2 (energetic and macro slam focus while adding better body and width)
Merason Frerot (a more neutral and sweeter micro focus with better organicness and nuance)
Holo Cyan PCM (focusing more on warmth, smoothness, and a wider and more spacious stage)
under 6k ish total used
Lot of good bang for buck pairings in this range, a good middleground to be in, provides a strong experience with these headphones without breaking the bank imo. I’d also suggest looking into higher end cables for the headphones, but nothing overboard, perhaps things around the 500 buck price point used.
Tube
Option 1: LTA MZ3
An MZ2 on steroids, similar characteristics but greatly enhanced in every way, see above.
DACs:
Lampizator Amber 3/4 (balanced but warmer and more spacious leaning, organic, fun, yet technical)
Mojo Mystique V3 (more of a warmth, forward, and macro focus with great space, impact, and weight)
Aqua La Voce S3 (neutral smooth, more micro focused, a bit more relaxed)
Rockna Wavelight (neutral slight warmth, pretty energetic and direct, great control and command)
Option 2: Eddie Current Studio B
Overall a very well balanced and nuanced pairing that focuses more on stage size, space, and lower level information and microdynamics without disappointing in the macro either, slightly warmer and richer depending on the tube, pretty detailed, solid control, great smoothness, great speed and separation, basically a very engaging and organic pairing.
DACs:
Mojo Mystique v3 (more of a warmth, forward, and macro focus with great space, impact, and weight)
Rockna Wavelight (neutral forward, pretty energetic and direct, great control and command)
Option 3: Allnic HPA-3000 GT
Overall a more neutral cleanly reference, no nonsense, organic but neutral and clean and refined, somewhat middleground between the two aforementioned, great overall control and extension, very direct and forward.
Meitner MA-1 v2 (warmer neutral, very natural and organic, micro focus, smoother and more relaxed)
Option 4: Cayin HA300
A warmer, sweeter, more rich sort of sound with a focus on sounding grand and warmer while trading a bit of technical ability for it, a bit looser control but organic presentation, great spatial recreation, fairly dynamic, a good all rounder if you don’t mind a more colored and richer sound and a slightly lower technical ability.
DACs:
Rockna Wavelight (Overall a more forward and energetic approach that’s cleaner and more controlled)
Bricasti M3 (Balanced slightly relaxed but really tightens things up and more neutral pairing)
Berkeley Alpha Series 2 (Pushes things more forward and linear but without removing sweetness)
Merason DAC1 (Really leaning into the sweet and smooth signature, barely not going overboard)
Solid State
Option 1: Mass Kobo 433
A really really well balanced option that hits all the right points with the Utopia while being linear and no nonsense, a great reference amp. The overall clarity without any harshness or inorganicness is impressive, it’s very strong resolving power and low level control exert a great feeling of energy and directness, stage is a bit on the smaller but very defined and accurate side of things, ever so slightly cooler tonal density but still fairly in the middle imo. Honestly really just well balanced and capable for the price.
DACs:
Meitner MA-1 v2 (A stronger micro focus but very technical and nuanced, reasonably well balanced)
Aqua La Voce S3 (Fairly neutral and technical but with a bit more relaxed and sweeter focus)
Mojo Mystique v3 (More of a warm and fun lean, stronger macro focus)
Bricasti M3 (Pretty balanced overall, very refined and composed, smoother leaning)
Option 2: Cavalli Liquid Gold
This does lean more toward weight, macro, control, and size, but doesn’t really fully lack in micro and nuance or anything but it’s not the main focus. Has great slam and impact, very macrodynamic and energetic there, stage has great width although slightly hazy, fairly tight and controlled despite punching power, nice warmer tonality, great timbre and tonal density.
DACs:
Rockna Wavelight (Overall slight more macro lean without sacrificing micro, great grip and control)
Aqua La Voce S3 (A bit of a more relaxed and sweeter pairing without losing any macro or energy)
Ayre QX-5 Twenty (More neutral forward focus but overall well balanced)
Mojo Mystique v3 (Stronger macro warmth and fun focus, very expansive and dynamic)
Option 3: 2x Questyle CMA800R
More of a micro and smoother focus, being very organic, liquid, and coherent while still having great control and technical ability, it’s a voicing that you’d think would end up somewhat lacking technical ability, but it’s able to deliver softness and sweetness without dropping the ball elsewhere. Having 2 really improves it, but only one is good as well.
DACs: (I’ve only really heard this with a few dacs so I’m not comfortable with making suggestions)
Option 4: Pass Labs HPA-1
Overall very well balanced with a slightly more smoother and softer lean, pretty technical and composed, really just refined all around, great all rounder pairing and suits the headphone well, not much more to say.
DACs:
Meitner MA-1 v2 (A stronger micro focus but very technical and nuanced, fairly relaxed and smooth)
Option 5: ECP DSHA L-3F
Something designed with Focal in mind, it’s an amp that is really great for the money if you can find one, a cleaner yet sweet and nuanced sort of signature, interesting contrast overall. Great clarity, great stage depth and placement accuracy, slight smoothness, fairly tonally dense, and great microdynamics overall, more micro than macro focus.
DACs:
Schiit Yggdrasil OG A2 (Overall really helps with macro and makes it a fun combo)
Holo May KTE (Tilts it warmer and richer and doubles down on micro)
Bricasti M3 (More of a neutral smoother option without going overboard and helps macro)
Ayre QX-5 Twenty (Keeps a more forward tilt with great energy without getting harsh)
under 12k ish total used
Things really start to take off here in terms of scaling, these could easily be stopping points for some as they really show you what the headphones offer without getting into the realm of entirely unreasonable. I’d also be looking the 1k+ range for a cable for the headphones. Also increasing DAC count to 5
Tube
Option 1: Eddie Current Studio T
Such a balanced, capable, and refined pairing. A more neutral and technical leaning pairing but very very organic as well. More micro focused with excellent nuance and lower level resolution, very very dynamic, very coherent and liquid, both very grand and very accurate stage, great timbre and tonality, and so on, really just does everything this headphone wants.
DACs:
Totaldac D1-Single-mk2 (Keeps the balance but adds more weight and impact which is nice)
SW1X DAC II Special (A sweeter forward lean but keeps technical ability and still balanced enough)
Lampizator Atlantic TRP/Baltic 3 (More of a forgiving fun with a slight macro focus)
Mojo Mystique EVO B4B / Pro (Stronger macro warmth focus toward fun while keeping refinement)
Berkeley Alpha Reference 2 (Very linear and technical pairing, extremely balanced and neutral)
Option 2: Viva Egoista 845
Something that takes more lean, clean, and explosive focus giving a very vast and precise stage, a stronger macro focus overall without disappointing in micro, strong impact and slam with excellent control as well, very fast speed and separation, with a hint of sweetness. I do think it’s slightly a bit too tonally dry at times and sometimes can be a bit overly forward but it can be tamed with the right pairing.
DACs:
Mojo Mystique EVO B4B / Pro (Keeps the strong macro focus but adds more warmth and meat)
Nagra Classic DAC (Dials down the macro focus to more balanced and slightly relaxes)
Lampizator Atlantic TRP / Baltic 3 (Fairly balanced still leaning toward fun but fairly technical)
Totaldac D1-Single-mk2 (Complementary overall, great balance and technical ability)
SW1X DAC II Special (Sweeter lean but still keeping forwardness and cleanliness)
Option 3: Woo WA33
Overall an amp that’s well balanced with a cleaner leaning signature that’s spacious, very balanced dynamically, and more a sort of reference signature. Surprisingly quick and well controlled, almost too much, I do think it can sometimes be too dry or slightly unengaging but a proper pairing can remove some of that concern.
DACs:
Weiss DAC501
Rockna Wavedream Bal
Option 4: DNA Stratus
While this isn’t my preferred signature, this is one of the few amps that I think does it well, it relaxes out the headphones and expands them a fair bit spatially, takes a stronger micro focus and great nuance, slightly more smoothed over transients and more sluggish but not mushy, more relaxed, great body and warmth, excellent timbre, overall solid if you want a more chilled out and more fun sorta sound.
DACs:
Mola Mola Tambaqui (Cleans things up a bit, better technical performance but still keeps character)
Berkeley Alpha Reference 2 (See above, but with larger macro focus)
Lampizator Atlantic TRP / Baltic 3 (Keeps base character although more forward and fun)
Weiss DAC501 (Balanced with a sweeter and more organic lean)
SW1X DAC II Special (Stronger lean into organicness and richness without losing control or balance)
Option 5: Modwright HA300
Somewhat in between the Woo and DNA, fairly balanced without catering to one side over the other, slightly softer and smoother with a slight micro focus but not disappointing in other ranges. Overall great all rounder with a more organic lean.
DACs:
Totaldac D1-Single-mk2 (Keeps that balance but with more macro capability and richness)
Mojo Mystique EVO B4B / Pro (Leans more into fun and macro forward warmth but not overly so)
Lampizator Atlantic TRP/Baltic 3 (See above but to a lesser extent, more micro focused)
Rockna Wavedream / Sig (Overall fairly balanced with a focus on space, grip, and control)
Bricasti M1 MDx (Leans neutral smooth, very liquid and coherent)
Solid State
Option 1: Mass Kobo 394 II
A 433 but better, see above, highly elevated technical ability.
DACs:
Totaldac D1-Single-mk2 /w live power (Very complementary, slight warmer and wider relaxed focus)
Berkeley Alpha Reference 2 (More dead neutral, very organic but technical and controlled)
Mojo Mystique EVO B4B / Pro (Focusing on macro with more warmth and space but still balanced)
Rockna Wavedream / Sig (Balanced but forward and slightly embellished)
Lavry Quintessence (Neutral but a warmer sweeter more relaxed lean that adds good weight)
Option 2: Crayon CHA-1
Something that manages to be incredibly fast and speedy but also smoother and softer, very very controlled and a stronger micro lean in resolution and dynamics but can sometimes come alive with macro if called upon, pretty unique overall, organic and very technical with a voicing that wouldn’t make you think that. Very liquid
DACs:
Berkeley Alpha Reference 2 (Brings it more forward with better energy and technical ability)
Mola Mola Tambaqui (See above but more balanced and sweeter sounding)
Mojo Mystique EVO B4B / Pro (More forward macro focus toward warmer and fun)
Rockna Wavedream / Sig (Somewhat keeps it balanced overall)
Bricasti M1 MDx (Still balanced but a smoother and more relaxed combo)
Lots and lots of options for sure, but out of those if I had to narrow them down even further, what would I go for? I might bend the brackets a slight bit lol, but this would be to force best bang for buck that might not have been an awkward middle ground if I went strictly by the brackets. I tried to keep it actually reasonable on what could be found used and average prices, but there are times where things will pop up at prices that would be perfect for the aforementioned setups, but I don’t want to make something that banks on rare deals
Top 2-3 in each bracket
3k ish used:
Exogal Comet Plus → LTA MZ2 + LPS
Crane Song Solaris Quantum → Bryston BHA-1
(If I had 1k more I’d swap the Solaris for a Berkeley Alpha Series 2)
6k ish used:
Mojo Mystique v3 OR Lampizator Amber 3/4 → LTA MZ3 OR Eddie Current Studio B
(If I had 2k more, I’d swap the DAC for a Totaldac D1-Core or SW1X DAC II Special)
Meitner MA-1 v2 or Aqua La Voce S3 → Mass Kobo 433
(If I had 2k more, I’d swap the DAC for a Totaldac D1-Core or Mojo Mystique EVO)
Rockna Wavelight → Cavalli Liquid Gold
(If I had 2k more, I’d swap the DAC for a Mojo Mystique EVO or Rockna Wavedream Balanced)
12k ish used:
Totaldac D1-Single-mk2 or SW1X DAC II Special → Eddie Current Studio T or Viva Egoista 845
(If I had 2k more, I’d swap the DAC for a Lampizator Golden Gate II or Wavedream Signature SE)
Berkeley Alpha Reference 2 or Totaldac D1-Single-mk2 w/ live power → Mass Kobo 394 II
24k ish used
Hmmm I’ll consider how to approach this later lol, too many options that I don’t exactly know how I’d allocate and what to go by
What about cables and digital sources? It’s something that I’d look into until you have the chain on your hands and know how you want to tilt things, and it will also really depend on what’s out there in the used market for a good deal since cables and digital sources can be very hit or miss in terms of value on the used market, but it’s still a good idea to have some things you are looking for
